I did a search and it looks liek these units are tough to get out..I am guessing i have to use some heat and a punch..Does anyone know if this is for both mounting bolts lower and upper?I took off the little pin on the top.It shot out somewhere!!!
If anyone has suggestions please let me know..
Also the used unit i got has a plug with 2 wires then it has 3 other wires 2 of them go to a mount for a ground then a white wire which is cut? What is the small part next to the trim called? What does that do? I thought the motor would move up and down if i add some power to the one side of the plug? Nope..I think the motor is shot?
