Help with RPMs fluctuating
impalor419
I have a 1989 130hp Yamaha outboard that been having problems with. When I accelerate anywhere in between 10 to 4500 rpms it runs great. When I push it to full throttle it goes up to 5900 rpms and then after about 5 seconds it backs down to 5000 and stays there most of the time but will jump to 5100 here and there. When I back off throttle a little it starts going from about 4600 to 4900 rpms. I have just replaced head gaskets, impeller, plugs, thermostats, exhaust cover. The compressions are great. 140psi on 3 and 135psi on the other. The carb has recently benn cleaned and rebuilt. I can say that this problem was going on before everything was done but the exhaust cover.
impalor419
Re: Help with RPMs fluctuating
What is the reasons for a fuel pump not keeping up?. Does it need to be replaced?
