jeremyp111
- May 31, 2003
- 51
Re: Help with shift interrupt
Just in case you can't come up with a solution to make the shift interrupt work you CAN install a Volvo SX drive without replacing the transom assembly. Volvo has a conversion kit that includes everything you need to do the job including an engine mount water pump (Cobra has drive mounted impeller). <br /><br />I believe the conversion kit sells for around $995 plus the drive.<br /><br />Good luck.<br /><br />Jeremy
