mr300z87
- Sep 15, 2010
- 701
Hi All, We own a 1990 310 Sundancer this is our first season with her and so far we are very happy. One issue we are having though is with the Vacuflush system. I knew from before purchase the seal between the bowl and the mount leaked so the system would not hold any vacuum, I have since replace that seal. The system essentially does function, but has a couple of issues. The first is if I leave the system on the vacuum pump (replaced last season by PO) cycles every 45 -60 seconds. The 2nd problem is when the pump runs I can smell septic and the 3rd issue is when my wife sits on the bowl it leaks water from the base. The bowl I have is raised version with drain out the back above the floor. If anybody is familiar with these system can point me in the right direction I would much appreciate it. Of course very few of the systems components are easy access. Also related but not, is the holding tank level system doesn't work either so I never know how much is in there. I did get it pump out last weekend.
Why these systems need to be so complicated I do not know. We would like to get this system to at least working with no foul odors coming from it. I would consider scrapping the whole thing and replacing with a good old fashion manual pump head.
Have a great weekend
