skisky89
- Sep 14, 2020
- 16
I've got a vibration that I can hear (and feel...lol), sounds like 40hz or so...
This is on my 1995 Sea Ray 195BR, 4.3L Mercruiser Alpha1 gen 2
This vibration is new! I must have done something wrong during my maintenance.. but where do start to troubleshoot?
This winter I removed the outdrive, replaced the impeller, and replaced the gear lube in the drive. I also replaced the u-joints.
My gimbal bearing was shot, I replaced it and aligned the engine.
Also replaced the alternator, it quit working while on the ears during my pre-float test this spring.
I installed an exhaust bellow (prev bellow didn't clamp on the out-drive side)
Prop seems fine, I think the same vibration is still present if I rev it to 2k RPMS on the trailer in neutral (water muffs on.)
What could I have messed up? The engine alignment is pretty straight forward. Is there a wrong way to put the U-joints on the yolk to the outdrive?
Thanks!
Thanks!
