Plainsman said:Welcome to iboats Jim!!
Can you be more specific? Could you give a serial # or year?
The guys here are the absolute best that you will find anywhere.
Laddies said:Just a couple more thoughts, would it be possible to remove(maybe drill it out) and replace the incert with a differant piece or clean up what you have and fill or seal with epoxy, if you fill the bottom of the piece with epoxy then drill and tap it?
ragu said:you could try a product called pig putty it is a 2 part epoxy the you break off and kned it together kind of looks like playdough then you can press it into the hole you have and when it dries it can be drilled tapped whatever withstands heat pretty good and is gas and oil resistant just a thought
