- Jul 23, 2011
- 52,485
Re: Here We Go: My 383 Stroker Winter Project
amazing what happens when the engine breaths.
Well I didn't end up buying a shop tach but I did play with props this afternoon. I did some GPS runs with the 23" stilletto and the 21" mirage with 2 blades with some minor damage.
23" Stilletto - 63-64 mph @4600-4650
21" Mirage - 61-62 mph @ 5200 rpm
all readings from the gaffrig tach on the boat. I didn't expect a 600 rpm jump from 2" of pitch. Must be the type of prop as well. I'd assume they would provide about the same speed if the blades weren't damaged on the 21" prop. The handling is great with both props too.
I am looking into buying an alpha SS drive. It is 2.75" shorter than stock and has a nose cone. There is a guy up in Maine that has one and I'm actually going up there this weekend and could go over and buy it. Any guesses on what it would do for me? 70? I believe it is a 1.32 ratio so I would need to use the 21" prop or maybe even a 19.
I think Tim has mentioned using an SS drive before. I'm not sure about the length. Are all SS drives shorter or has this one been shortened?
With those MPH/RPM and pitch differences I would guess that a good labbed prop of the appropriate pitch and dia would get you well over the 65mph hump with your current drive. Maybe time to get on the phone to some good prop shops.
Where in Maine, I lived there for 7 years.
pretty respectable numbers there Greg. may want to actually talk to a prop guy to get you dialed in the rest of the way.
http://boatpropellers.iboats.com/Me...-143-22_Propeller/769/9547/?*******=425723598
That prop should be right on the number's..Not as much cupping as a stilletto so 4900-5000. Or labbing the Stilletto but that's some dough about 400. It's hard to find a even pitched 3 blade and the solas is a great prop
Yep, alpha ss is almost 3 in. shorter. I have one on my 88 Rinker, upper gear case is shorter. If you get it, be careful as most parts are NLA.
