hey bondo, check this out....a turbo charger for an IL6
FreeBeeTony
Re: hey bondo, check this out....a turbo charger for an IL6
Hey bondo,<br /><br />Yes i spoke to one of them, the other was out of town.<br />Sounds like a match. I'm just a little concerned about my FWC system........put alot of work into that as you well know. Will the raw water be able to exit via the elbow still? I'm not so sure.....can't tell from the pic.<br />If I can get it cheap enough I will probably go for it......<br />I may have to "re-jet" the carb. Will I have trouble getting the jets for this carb? Think its a Rochester.
Off the top of my head,<br />I can't answer your Questions.........<br /><br />But,<br />As You well know,<br />I'm the King of Creative Engineering.......................... ;) <br /><br />I'm Sure that we can find "Work-arounds" for Any Issues that come up................... :D
FreeBeeTony
What about octane? Will the tirbocharger increase the compression causing a requirement for higher octane?<br /><br />The auction is almost over............... :)
You may want to go to a Mid-Grade fuel....<br />Or,<br />Cut Back on the Timing alittle.......<br /><br />I can't believe that it'll build more than 3psi/4psi.... Shouldn't be an issue.......<br /><br />That little white book in the pic Should have the Answers.......<br /><br />3hrs to Go.........<br /><br />A Google turned up This,<br />M&W Gear Co. is located at Rt. 47 South, Gibson City, IL 60936, 217/784-4261.<br /><br />And This,<br /> http://www.mw-gear.com/
FreeBeeTony
It's starting to move.......don't know how high I want to go.
That's Your call Tony.....<br />I think a couple hundred will buy it.......<br />It no doubt cost 2 or 3 times that when New......... Which it Still Is, by the way......<br />An hour to go,+ it's only at $107.50.........<br />Did you Ask the guy what his reserve is ??????
FreeBeeTony
The guy I spoke to said he didn't know what the reserve was...........
FreeBeeTony
You must be watching this just as close as I am......... :D
Ayuh........................ :D
Tony....... You Won.........<br /><br />You didn't crack the reserve though........<br />Call them up,+ see what they'll take..........
FreeBeeTony
Well.......auction ended...........<br />I was the highest bidder but did not meet the reserve.<br />I am going to cal them tomorrow to see if we can make a deal!
FreeBeeTony
His reserve was too high. I made him an offer on the phone and he is going to let me know.......<br /><br />How did you know that was me????????
What is his reserve ????<br /><br />"How did you know that was me????????"<br /><br />Your ebay Code Name.............<br />It's your Initials.........<br /><br />Remember last winter, I put your check in the Beer Fund................. ;)
FreeBeeTony
bondo...what's your email?
Tony,<br />You've got Mail........<br />It's in your optonline box.......
FreeBeeTony
They sold it out from under ME........<br /><br />Oh well......it was fun while it lasted!
ron7000
Banned
Originally posted by Northern Eclipse:<br /> I'v seen a pair of Twin turbo charged Merc 454's in a 38 Fountian, he was pumping out over 1,000 ponies between the two engines, You should hear these puppies whine ...
sure that's not the "super"-charger you hear?<br /><br />
Originally posted by FreeBeeTony:<br />I see what you mean, the carb is "before" the "fan" and the air/fuel mixture is being "sucked-thru" the carb
air/fuel mix leaves the carburetor,<br /><br />and passes through a set of turbine blades spinning at 10k rpm +,<br /><br />and is compressed to 3 psi (you know when you compress a gas is heats up?)<br /><br />and passes a turbo which absorbs exhaust gas heat of around 1000-1400 deg F.<br /><br />what's wrong with that?<br /><br />that puppy must have one hell of an intercooler :eek:
Northern Eclipse
Ron7000 , No they were not superchargers, they are turbos, This is on a old Fountain, I know the owner of this boat, But I can understand why you question whether or not I'm confused since Its the only Offshore Rig I'v seen with Turbos also.
Ron7000,<br />At a 3psi or 5psi boost, an aftercooler is Not necessary...........<br />
This is on the Exhaust side,+ quite irrelevant.........
mercrewser
Not sure if you guys realized this but that turbo is for the 4 banger series Mercs (470 etc). He says its for 1978- mid 80s. 250 I6 ended in 76 or 77 I believe. Those 4 bangers had aluminum heads.
