high oil temp 496 ho
Sikboats
Hi ,
Customer claims oil temp running real high in 2007 fountain lightning on starboard motor , say got up to 290 but says water temp 160? Any idea's?
Sikboats
Re: high oil temp 496 ho
The interesting thing is the customer claims when he opened the hatch the motor was hot. The Impeller was changed a week ago with no debris in system. I know the temp reading is accurate because I ran on the lake. never heard of high oil temp with normal water temp.
Philster
The most oil temperature susceptible parts are the engine's crank and rod bearings. The water cooling system would go on fine, but the oil would take it on the chin if there were problems here.
Also, does the owner guarantee they are using synthetic oil as recommended?
From driving an Infiniti G35 Coupe with all the sport goodies, I've learned that there are a number of newer engines that have susceptibilities to high oil temps, while water coolant temps stay quite normal. Time and time again, it comes down to the bearings, their health and how hard you drive. If you run and gun, the word on the street with the G35 and Z car crowd is "get an oil cooler". Your typical commuter wont see a problem.
Other affected vehicles: C6 Corvette and BMW 330. What we have is high oil temps and normal coolant temps, with liability down near the bearings. The 'fix' is a quality oil cooler and synthetic oil. Bearing failures are becoming more common. Rumor is that manufacturers of bearings to the auto industry were forced to 'green up' their manufacturing process, and some harder materials used in bearings have been removed. A small percentage of those with H.O. version of certain engines with a tendency to push 'em are the ones who notice the problems. Most don't notice, or most don't push hard enough. Many just have older/harder bearings. So, we have signs of bearing failure, or signs of oil effectiveness being reduced to the point of internal failure, starting at the bearings. 290? Wow, that is believable, because that is in range of the high oil temps related to bearing issues. 260 to 290 or higher has been reported.
And what-do-ya-know, ya got a 2007 motor. Fits the bill. Heat down near the bearings. High oil temp. Increased wear. Reduced oil performance. Normal cooling temps. :mad:
Sikboats
Interesting, I will have to get a temp gun to actually see. Normally you won't see oil temp gauges with stock motors but it is a fountain. I used the mercruiser oil 20w-40 synthetic blend on the service with factory oil filter etc.
Philster
Let us know. All the pieces add up to the bearings.
joncrisler
I am not sure a temp gun will give you an accurate reading- it depends on where the oil temp sensor is located. There are also different sizes for oil coolers, so your customer could possibly get a larger oil cooler.
Fun Times
You might want to make sure the oil cooler is clean,ect.
The oil cooler could affect the oil temp, But not the water temp or the water Pressure in some cases.
Sikboats
I will check the oil cooler, didn't think water temp would hold with oil temp that hot. Thanks all for your input.
havasuboatman
Ensign
Is the oil cooler installed?
Is it installed in the right place?
How did you verify the oil was that hot, by looking at his gauge?
Was the motor hot when you test drove the boat?
Customer said boat was running 140, but hot when he opened the engine lid?
Sikboats
Checked all hoses for blockage today , clear. Noticed Belt on motor to be looser than other motor , same part # but looser. Customer told me today that oil temp goes to 290+ during and after run but will go down to 140 at idle of course this all didnt start happening until service was done says oil pressure is running lower as well. Noticed power steering cooler to be like a heat exchanger type although mercruiser says it is a straight through cooler. It has a Latham steering sytem ,do they make their own coolers or is the merc wrong? Changed oil filter in case check valve is bad and asked customer to go run , swapped belts on motors as well.
Sikboats
Well , turns out that it was a bad oil filter. Everything back to normal......
