Shadowbird
- Jul 15, 2006
- 7
O.K. 1973 Mercruiser 888 has new wires, plugs, cap, rotor, rebuilt carb, and new points. All are set to specs. Timing is perfect at idle. Motor runs great until 2000 rpm and then the tach is all over the place cuts out and sounds horrible. If I go wide open throttle it will die. When I replaced the plugs all were oily, fouled and black. The motor was rebuilt 20 hours ago (Ford 302). Any ideas???
Thank you,
Travis
Thank you,
Travis
