Higher elevation issues.
I agree. That’s what led me to believe the motor height is wrong and I need to drop it a notch. There are so many variables though, where do you start? Weight distribution is a factor as well, right?
Drop the motor down and make sure the prop AV plate is just above the bottom of the keel
Prop style also plays into it
dustyjohns
No I haven’t even thought about it. Totally makes sense as something to check though! Thank you very much.
dustyjohns
Hull appears to be fine. Local boat shop recommended a 15.6 X 13 3 blade Turning Point. So I tried it Sunday. Boat hopped up on plane and had plenty of throttle left. So now I just need to get back up to the higher lake and see what happens.
I can’t thank all y’all enough for sharing your knowledge and helping me. Thank you all so much!
