hinge pin access
lucky7
alpha 1 gen 2
do need to remove the trim senders to get at the hinge pins? manual has no diagram i could find..
thanks
Bt Doctur
Re: hinge pin access
Your Mercruiser manual dosent show it? If you dont have the real manual visit the Adults Only section to download a free one for your drive.
Yes, the senders are removed to accesss the hinge pins.
lucky7
thanks, i thought there would be a zerk for them, but i cant find them or they were discontinued. the book says to grease them, so i guess ill back them out one at a time and grease them.
Ayuh,... Most of the Mercruiser transom assemblies are No longer Grease-able...
Your's is of the Non-grease-able variety...
What manual are you lookin' at,..??
lucky7
i have the 'warentee and service" one that came with the boat, and i downloaded #31.
cr2k
Another "better idea" from Gen II.
Don S
Try downloading #14, it's for the drive. 31 is for engines. Maybe yours, maybe not.
lucky7
thanks. done. you guys are a great resorce,
