ugbandtulsa
- Jul 2, 2006
- 34
Is it possible to remove the upper transom hinge pin and replace it on an alpha one Gen 1 without pulling the motor? I believe this is the proper term for the pin, but if not its the one at the top of the transom assembly, that allows the side to side movement of the drive. It's worn out and getting dangerously loose. Any tips for that, other than to bite the bullet and pull the motor?
If not, how many hours does it usually take for a good mechanic to pull and replace a 350?
Thanks!
87 formula 272
Alpha ones, gen 1
Vortec 350's
Thanks!
87 formula 272
Alpha ones, gen 1
Vortec 350's
