Hello,
First time on iBoats, so let me know if the subject doesn't fit this category and or if this already exists (I searched older topics and couldn't get something similar to mine tough).
I have a 1989 Larson All American 170 with a 3.0 Mercruiser engine and this weekend I was in the lake (Ray Hubbard - Dallas TX) and was relaxing and fishing with the boat turned off when my girlfriend told me we were too close to the shore. When I realized the distance I tried to start the boat to get far from the rocks, however I didn't count that I was already on the rocks and as the engine started the propeller hit the rocks, the steering wheel turned abruptly and engine went off. I needed to jump in the water (it was shallow) to drag the boat against the current and waves to stop if from hitting the rocks. After some heart attack minutes I was able to drag the boat to a place without rocks, started it and went away. The three blades of the prop got damaged but the boat was running until it started to slow down and turns off. I wait a bit, started it again (I needed to reach the marina at least) and drove a couple minutes more at a very slow speed even with full throttle and then it died again. After that I saw that the battery was low and the boat didn't start again, and it makes sense because of all the time I tried to start the boat, probably the alternator wasn't being able to hold it all and charge the battery - however battery is not the issue.
What else, apart from the prop (which I have already bought a new one) should I be concerned? Was the boat not keeping it up and dying because of the prop that was messed up and couldn't keep the power up? What else should I check after replacing the prop to make sure I didn't damage anything, such as steering wheel calibration?
