Hitch ball hight ... is there a standard ?
pecheux
Good day,
I wonder if there is a standard hight (from ground) of the ball mounted on a hitch ? Or is it a question of vehicule hight vs trailer type. Tx
Gary H NC
Re: Hitch ball hight ... is there a standard ?
You need to use the correct size drop for the trailer to ride level.
Knightgang
Hitch ball height can vary by trailer. The key is for the trailer to ride level, just as Gary stated...
cooter2506
I tow 6 different trailers and have 5 different drops for it to fit my truck. They make my trailers ride level. My wife is tired of seeing all my balls lying around the garage!!!!!!!!
Fun Times
Good day,
The most important thing is to get the trailer to ride level, But the average hight normaly seems to come in at around 18 to almost 19 inches sometimes from the ground to the top of the ball not hooked up to the trailer, Then try to level it out from there if needed.:)
woosterken
pecheux,
like the others said you want the trailer level, here is the chart that came with my hitch
to figure it out...........
woosterken
J JACKSON
at least there not in her purse
kenmyfam
Trailer should ride level. Bottom line. One reason it is difficult to tow directly off the bumper in most cases.
floatingwoody2006
I have an adjustable type that goes up or down with a wrench, and ball's are a quickchange with the spin of a flat screw. Saves Much aggrevation..
pecheux
Thank you guys ... all of your explanations say it all. Woodsterken: thank you for the picture.
Jeep Man
Really tempting.......But I am not going there.
reelfishin
While most trailers do vary, I'd have to say the average tow height of most is about 18".
Boat trailers often vary by tire size though, the key is often to get the boat as low as possible, this means that the tongue is often pretty low.
I have 12 boat trailers, all but one tows at 18" give or take a 1/2" or so. The same for most of my utility trailers.
smclear
I was always under the impression that the height should be at a point where you will achieve approx. 10% of the gross weight of trailer load on the ball. This is critical in how the trailer will "ride" behind your vehicle. Too much weight on the ball is not good but too little can be downright dangerous.
Knightgang
Tounge weight and tow ball height are two completely seperate things...
pecheux
pecheux,
woosterken
My original setup was as per the right hand side pic. The tongue was low but the boat was straight. Then on a rainy day I realise water would not empty via the rear outlet so I swithed to the left hand side setup ... Now the boat noses up but the trailer is leaning back slightly ... enough for the water to exit. I think I may need a straight hitch bar to make everthing even. Tx
jeeperman
A new drawbar is a cheap fix.
And really when trailer is not hitched you store it bow up for good draining.
pecheux
This small boat kit lives an easy cat like life ... sleeps in the garage ... LOL
