Re: Homemade Lower unit tester
I done my pressure test and found a leak, one my output shaft bearing carrier bolts with the rubber backing was blowing bubbles, now goin to do a vacuum test, so if you lose vacuum how can you tell where its leaking?
OMC stringer 800 outdrive
