Hi,i have been thinking of making a water heater for my boat.its a regal 242 cabin cruiser and does not have hot water plumbing to the fixtures but has the inline electric water heater.it does not work very well at all.my idea is to put the copper wound tubing in the can ,weld it back and pipe the transom shower hose with it.i dont want hot water throughout the boat just at the back for a warmer showeroff before bed.i plan on going between the tstat housing and manifold.to avoid air trapping i would put the inlet of the water in the bottom and let it fill up and then push water to the manifold.the shower is about a 1 gallon a minute rate so it should be slow enough to make somewhat of a heat exchange.my question is about the plumbing,do you see a problem with going between the manifold?is there a better way of doing this,aside from a normal water heater which i dont have room for anywhere as its all taken up with batteries,generator,a/c,and holding tanks.its tight allready.like i said i dont need gallons of hot water ,just enough heat to make a more comfortable spray down.any suggestions are appreciated.
