I've been away for a while but I started looking at the engine again....
I dropped the midsection/lower unit so I could insert an inspection camera up the exhaust. I was able to identify where the water is supposed to come out...it's only about 3 or 4 inches from the tip of the exhaust.
unfortunately the camera couldn't fit inside that hole so I couldn't observe any blockage.
I also used the camera to attempt to view the water passages in the head. It didn't quite fit there either but I was able to see one important thing - the downward pathway from the head to the exhaust. I could just barely see it. Not enough to see any type of blockage.
once again I used my air compressor to confirm that the blockage is at the exhaust water pathway.
I tried weed whacker line to try and snake it out from the bottom and the top. no luck.
Can I use something like a coat hanger? And does anyone know if there's a 1 way valve in that passage? I'd hate to use a hanger going the wrong direction if there's a valve.
