Honing/Boring
paulwjax
I have a 1974 115hp Johnson that has light scoring in the cylinders and was wondering if I should do the honing/boring work or have it sent to a machinist.
Also, if I were to do the work I saw Flexhones in a bunch of different grits. Which one do I use or are there multiple grits to use?
wilde1j
Re: Honing/Boring
If you can't tell whether it needs honing or boring, I would suggest you have a marine machine shop bore the block (it's not a DYI deal) and install the smallest oversize pistons and rings. Let the machine shop tell you the oversize needed and make sure to tell the piston you'll use.
BTW, Mar-Fab is a good shop.
bashr52
Re: Honing/Boring
Light scoring can be honed out, deep gouges need to be bored. I have both a straight honer and a ball hone. I love the ball hone, it leaves nice cross hatching on the cylinder walls. You can do the same with a straight hone, if you are good with it and know what you are doing. I agree though, if there is any doubt as to what it needs, take it somewhere to get checked out.
wilde1j
Re: Honing/Boring
You need to start by using an inside micrometer in the bores and also check for roundness of holes. If within specs, honing may work, but I doubt it for a 35 year old motor. BTW, what was compression all around?
Dhadley
Re: Honing/Boring
Second that. If you don't have access to a dial bore gauge then let a outboard machine shop (not automotive machine shop) measure it and make a recomendation based on size.
If you have a piston that needs replacing, go to the first oversize and bore that cylinder.
Don't mess around with a shop you are not 100% positive about. Mar-Fab is at least 100%. So is Flagship in Punta Gorda, just in case you want to use someone in Fla.
paulwjax
Re: Honing/Boring
I'm not sure what compression was since the motor wasn't running when I got it. (Free motor) The pistons were stuck in it but any rust in the cylinders has come off with wd40 and 0000 gauge steel wool. It was sort of a "ran when parked" deal so I just decided to rebuild the thing from the ground up instead of trying to put bandaids on little problems.
paulwjax
Re: Honing/Boring
I'll have inside measurements soon. Northern Tool was out of micrometers that read to thousandths when I went in.
kenmyfam
Re: Honing/Boring
Without a doubt you need to check the bore dimensions. How bad is it ????
paulwjax
Re: Honing/Boring
It's not great but I've seen worse. Also, with 0000 gauge steel wool the rust goes away.
I've attached 2 pics of the cylinders. The first is what it looks like after I steel wool the inside and the 2nd is the worst cylinder on the powerhead. None of the cylinders have grooves in the lip.
kenmyfam
Re: Honing/Boring
Check with the bore indicator and compare to original spec's
Faztbullet
Re: Honing/Boring
From the looks of cylinders, I myself would go ahead and bore due to the rust issues, if its rusty it is pitted. A few pitts here and there wont hurt anything but from looks it is 360 around ports. Also make sure of year model as there is a BIG difference in a 1973 & a 1974 piston(wrist pin height).
paulwjax
Re: Honing/Boring
I've found a shop in town that does boring for about $20 a hole that a few people have used with decent results. I'm going to go for the smallest overbore possible.
It's definitely a 74. The silver tab on the powerhead says 115esl74b but I still went to check just in case. :p
Dhadley
Re: Honing/Boring
Be very careful. Ask the shop what they use for the finished bore size. Let us know what they say.
