jerryjerry05
- May 7, 2008
- 18,185
Carb kits: they include a gasket and the soft plugs and maybe a spring.
Maybe a float?
I'd pull the bowls and check the condition??
Then if really crusty I'd order the kit.
The welch plug can be easy to replace or you can screw up the carb??
Most times the gasket is all you need, unless it's really crusty and needs a chisel to remove the crud?
Spray WD on the bowl around the gasket and let it set 24hrs.
This softens the cork and when the bowls dropped it might not get ruined.
Cleaning: Some carb soaks eat rubber, plastic.
The seat or needle might have rubber or plastic and the soak might destroy it??
I use Dawn soap and a can of carb spray.
The spray is for the passages you can't get with a brush.
Wash with dawn and rinse with clear water and blow dry.
Then reinstall fairly soon.
Just make sure the waters all gone.
The air screw: Turn it in slowly and count the turns.
Reset it to the same spot when done.
While the carbs are off, check the reeds.
Maybe a float?
