has the impellor been replaced recently and if not it may be wise to start there as i know norway will starting to get near the freezing weather this month.if in the process you find any missing pieces it may well have blocked up a passage and if your really lucky it may be around the thermostat housing and its related pipework.if your unlucky it may require the heads pulling to see if water is flowing through the block and heads good.was the manifold of good structural quality ?
the y pipe has flaps in there too and they must be still there and not block the outflow by being stuck in the lower section and sometimes thyis can be seen with the leg removed.if you have acess to a digital laser thermometer it may prove a good investment and there quite cheap from the correct source.
a cheapish one here but ?9 to norway delivery; http://www.ebay.co.uk/itm/Non-Conta...urement_Equipment_ET&hash=item2eb88d25a9#shId
When I was looking from behind it didn`t come as much water out back at the transom on the right side (which is the hot side), but the water was very hot, on the left side it was more water, and normal temperature,
jtracc it should come out both sides.
Hi
Does anyone have an idea why one of my riser is much warmer then the other one?
I have had the riser and manifold off, to flush out dirt, but it didn`t help.
