Re: Hot Water Tank - BUSTAMAKATED!! BRRRRRRR
BRRRR, so the hot water tank just gave up the ghost yesterday and the guy that installed it 4 years ago will not be available to look at it for a week, as are the rest of the plumbers in town, so I guess it up to me!
So were do I start testing?
Thermostat, elements?
Thanks
Rob
Assuming that you mean hot water temp rise = 0 :
If you are OK with a voltmeter, after you have verified that the breaker is not tripped....if you have fuses, that
BOTH are good, ensure that you have 240 Volts across the thermostat, and at the upper heating element.
If you have voltage at t/stat and heater....disconnect heater element and check resistance on 0-50 ohm scale if your meter has one. 0-100 if not. You want a resistance of 10-20 ohms (depending on wattage....in that range anything is pretty much OK unless you have a really good meter.)
If resistance is ~ infinite, your element is blown....and in my experience that is the most frequent event by far.
Replacing is not tough. Lots of help here if needed.
If it is not a heating up issue....I've wasted my time typing this out....and you've wasted yours reading it.
