How bad did I screw up?
Jacket4life
Re: How bad did I screw up?
Hi!
I understand some of your issues, and I know you want help or you wouldn't be here. I'm sure everyone is doing their best to help, but if you don't know, I'd take their advice!
Starting with the battery is logical, easy, and best of all, CHEAP! That's something you are about to find out is NOT common when dealing with a boat! If you look around here much, you'll find out that boat is an acronym for Busted Out Another Thousand!
Really, you need to know what the deal is with the battery before you do anything else. Boats do not use regular automotive batteries, they use 'Deep Cycle' 12V batteries. One of the differences is the way they need to be charged. They require slow, steady, 'trickle' charges. You need a charger that puts out 2 amps or so, and leave it on the battery for 12 hrs. minimum. Then you need to be able to check the voltage like ajgraz reccommended, AND I wouldn't take the boat away from shore/trailer until I knew whether or not the battery was being charged when the motor is running. You can do this by checking the battery with a volt meter while the engine is running, or by checking the charging system while it's running. On my Mercury, the voltage at the battery while the motor is running and charging is around 16.5 volts.
After you ascertain where you are with the battery, you can proceed with trouble shooting everything else.
Funny story so you don't feel so bad. When I was a lot younger and got MY first boat, I had a similar issue. I charged the batt. for a whole day, nothing. Had no volt meter, so I pulled it off and took it to the store to buy a new one. They tested it and said it was good. I take it back, clicking and CLunk from the choke, but won't turn over. Take the cover off, starter engages but won't turn the motor over. Getting pissed, take the top cover off thinking I have to pull the starter and replace it (which, if you don't know, starters for boat motors are RIDICULOUSLY high!) When I get the top cover of: HUGE dirt dobber nests ALL OVER the fywheel and nosecone of the starter. Clean it all up, motor fires right up! LOL.
Welcome to the world of boating, hope you have as much fun as I have!
Best of luck.
ezmobee
He won't need a deep cycle just to start an outboard. I'd recommend a marine starting battery.
sschefer
yup, you will ruin a deep cycle if you use it for starting. But there are combo start/deep cycle batteries made specifically for Marine applications.
maxum_man
I have a 1992 120 hp Force on a maxum 2100 and it is oil injected! You might want to look around under the "hood" and check to see if you have an oil reservoir...or go through the manual as previously stated.
Batteries are cheap! $68.00 at Wally World for a decent starting battery.
backpain
If he gave you the reciept for the new battery, take it to the store he bought it from and get a new one or at least get it tested. It is an easy and free first step.
dirkmc3
My buddy's wife put deisel in the gas tank of her shiny new crotch rocket by accident once.....does wonders for fuel injection systems...lol
