How did my outboard get holes in the pistons?
BigB9000
Outboard is a 75hp johnson, year is 81
pics:
I couldnt get a compression reading from the top 2 cylinders, but the bottom had 30psi (the one without the hole in it)
How does this happen? or are they supposed to be there? and whats with the clean spot on the pistons?
F_R
Re: How did my outboard get holes in the pistons?
Am I blind? I don't see any holes. Or are you looking at that little hole in the center of the piston? That is a centering hole to center the piston in a lathe when it was made. Absolutely normal. It doesn't go thru does it?
BigB9000
all the way through. a needle go in untill it hits the connecting rod. But why is the 3rd cylinder different from the others? why have that dime sized area on it?
lbentz
Well, let me get this straight. each of the cylinders have a hole in the center, that goes clear down to the connecting rod? Are these holes cleanly cut? Or are they like burned through?
Well, if they are machined through, as in drilled and such, then I wouldn't be too alarmed. I think your compression problem may be your reed valves.
Leon
BigB9000
No, only 2 pistions have a hole in them. smack dab in the center. You can easialy see it in the pic.
2 cyl have them, 1 dosnt
(conviently the pistion without the hole was the ONLY pistion that has compression)
So, yes they are clean cut, almost like they were machined.
But, why would only 2 have hole, and not the 3rd?
And whats a reed valve?
(the thins on the inside of the intake manifold?)
rupertmja
Looks like the holes are the original machined holes. My bet is they do not go right thru and that your rings were probably not sealing. Probably needs a rebore. The bottom piston - it has most likely been replaced at some point. Some people rebore one cylinder in two-stroke engines, leaving the other two as they were. Of course, it is best to rebore all of them at the same time. Does it have any oversize numbers on it? Shiny bit - looks like a bit of carbon has fallen off. Did you use some carb cleaner or anything before you dismantled it? Some carb cleaners are great at removing carbon.
PS I think you need to tidy up your garage. My mate's is the same and he can can never find anything. Tell me it ain't true.
F_R
OK, so they aren't centering holes. Whether or not pistons have centering holes depends on whatever manufacturing process they use to make them.
Now, the big mystery is why do your pistons have holes drilled all the way through the pistons? I don't have the slightest idea. By the carbon in the holes, it would seem that it has been running that way. Pistons burn holes through often enough. That is caused by pre-ignition. But in that situation it is an obvious burn-through, not neat little drilled holes smack in the center.
As I said, I don't have the slightest idea why your pistons have holes drilled through. It would seem like a very dumb thing to do.
BigB9000
Yeah, the place is dirty. Its actually a lot worse than it looks, thats the trick photography for you. But thats from trying to put the (new to me) 19' boat, into the 18' garage. I had to throw things out of the way, off the racking, etc to get the thing to almost fit in there. If the racking wasnt there Im sure the boat would fit right in.
Now I just need to decide whats more important to me, the racking, or the boat fitting in the garage
Pleasure Boat Junction
Looks like a former owner had an enemy who destroyed it on purpose by drilling through the spark plug holes. Bottom one doesn't have a hole because the pan is in the way. Just my guess?
BaileysBoat
Are the holes the same size ?
NelsonQ
They'd be quite skilled to hit it that dead center and clean a hole. Certainly looks weird to me. Never heard of it. I think we're all in agreement this isn't normal.
Hoping some of the experts who've done years of this stuff can explain.
Tim Frank
Bizarre!
If some sicko did get loose with a drill, the metal shavings would have fallen into the cylinder and there would be evidence of scoring at 6 o'clock on the cylinder wall. Might have messed with the rings, too.
Drilling through a spark plug hole and free-hand, that is a pretty precise job, though.
BigB, are there any longitudinal scratches on the cylinder wall?
itsaboattime
The only holes I've ever seen in pistons have been burnt there by plugs that were too hot. They were big ol gnarley holes too!!! Not neat lil round ones that look machined.
Have you had this motor for a while?? Did it useta run?? If you just got it I would talk to the former owner and find out what happened.
Joe Reeves
Those holes do not belong there. Somebody somewhere does not like somebody.
CATransplant
Yup, it appears to me that someone has sabotaged that outboard. Not a good thing. You might want to speak to the previous owner and get the story of that outboard. I'm betting it quit running one day. He might even have an idea who did it...not that it does you any good.
G DANE
Not relevant to your question, but it looks like an Evinrude to mee, most Johnsons are white. Sure looks like the common center marks on some piston brands. Are you perfectly sure they go thru the piston ?? Put a wire down as long as you can, and mesure how much. Your problem might be blown headgasked, sticking rings or something else, much simpler to adress.
Only way I can see anybody hit that well thru spark plug hole, is that they drill in a center mark that is already there, and there is almost no possibility thay can see where they hit, as spark plug hole is the only opening. Sounds weard if there shouldnt be marks beside the right dean in center hole. Better recheck. Cant imgine anyone taking head of to drill holes in 2 of 3 pistons, might do a lothers to sabotage.
Sorry for doubting.
jonesg
fix it!
I think I'd at least try tapping it the next size up.
screw a bolt in and cut it off flush.
noelm
not too sure I would be putting a bolt in my pistons and cutting it off, but to each their own I guess, first off, I guess it is really remotely possible that the pistons had the machine holes in the top from new, and it has been running way lean and burnt through the thinnest part (the tiny indent in the centre) very unlikely though, more than likely, you are mistaken and only think they go right through and there is some other problem causing your no compression on those cylinders, like it was rebuilt with 1 new piston (the odd one) and now something else has crapped out because of the cheap patch up rebuild!
BigB, I don't think it is mentioned, but did you check to see if air would blow through the holes?
BigB9000
A finishing nail will go 3/8 - 1/2 inch in before hitting something.
Other than carbon, it looks clean the 3rd piston was probably a replacement, it has numbers all over it. Inner cylinder walls look clean, no schraches. If the hole wasnt so deap, I would agreee its from a lathe. But Im not quite sure about that. But unless somebody drilled a perfect hole - this happened on its own.
I would also agree that engine failure lead to the weaking of the hole.
I Dont feel like putting my mouth on it to see if air goes through, and I couldnt tell with a little hose.
The outboard was/is a royal peice of crap. Somebody spray-painted it blue, and used random fastners all over to probably rebild it. None of the screwes were very tight, the flywheel pin was sheared off, carbs linkage was held together with zip ties.
Just all around a pile.
So I took It apart.
