how do i see if the flywheel key is sheared on my 48hp
S snake91876 Petty Officer 1st Class Joined Jun 25, 2007 Messages 211 Sep 28, 2009 #1 how do i see if the flywheel key is sheared on my 48hp
bktheking Vice Admiral Joined Jul 29, 2008 Messages 5,057 Sep 28, 2009 #2 Re: How do i check for sheared flywheel key Pull the flywheel off.
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 28,129 Sep 28, 2009 #3 Re: How do i check for sheared flywheel key Remove the spark plugs and turn the motor until the top piston is at TDC. Use a screwdriver to get it as close as you can. Now see if the timing marks indicate TDC as well.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Sep 29, 2009 #4 Re: How do i check for sheared flywheel key http://forums.iboats.com/showthread.php?t=299680
