ottawamerc
- Sep 16, 2004
- 128
Hello
have a 1987 Sea Ray 268 with a 260 Mercruiser, It's new to me and I put a new engine in it this year. It doesn't seem to want to run WOT it has a 16X16 3 blade and a 16X?? 4 blade prop. It will only get to about 3400-3500rpm and takes a bit to get there. Under the Sea Ray web site there is a chart that says that combo should have a 1:5 upper gear set, I'm thinking it may have the wrong gears in it and I would like to check to confirm what is in there. So how could I do that with the outdrive attached? The chart also says that it should have a 15.5X15 prop, could the 16X16 cause that much RPM change?
