How do i reset a ECU error code ?
Dogfish_magnet
Hi - i had a problem with my DF60, it would not start / idle correctly and was showing a diag error 31 - IAC, i have replaced the IAC and the engine now starts & runs but the error is still showing and the beeping is driving me nuts - can anyone tell me how to clear the error ?, I've tried disconnecting the battery but it hasn't helped.
Thanks-DM
clanton
Re: How do i reset a ECU error code ?
If it is a Suzuki, it will clear, when repaired and key is turned on.
Dogfish_magnet
Thanks - Yes its a Suzuki - I must have another issue then as I'm still getting the error but the engine is running OK after replacing the IAC.
clanton
Disconnect the connector and reconnect a few times. Check wires.
