How fast should a 305 228 hp go?
welovetoboat
Just bought a 1979 18 foot Thunderbird Formula. with a mercruiser 305 228 hp. Starter was out when I got it. Put starter on - RUNS great (so far). When we purchased it the guy said it ran 45-50 with 4-5 people in it. Speedo says it is going 37 full throttle with 4 people and NO COOLERS OR EQUIPTMENT. Thought maybe a tune up may help??? Any thoughts on how fast it should go or what may help give it a little more power. Seems kind of slow for a motor of that size. Our old boat was 135 hp and went 35.
captmello
Re: How fast should a 305 228 hp go?
What RPM's are you getting at that speed. The speedo could be off. If your measuring speed without GPS your wasting time. I think that boat should do 45. Not sure about 50.
Ayuh,... Yank the 305 out,+ Drop in a 350....
dgopetactical
your 7 mph off from the past owners lowest observation when he owened the boat..I dont think your off too much.
Water conditions and the way you trim the boat etc. could eat up them mph in a heart beat. Give her a tune up and play with your trim when your out. I would not freak out your speeds sound real close.
Its hard to say how fast you boat should go, you could take 2 exact boats set them up the same and get big differences between the speeds. As I said before water conditions and trim are a big factor. My boat can differ 5+ mph in water conditions from glass to a minor chop. same with trimming too low or high.
I have bought a few boats over the years and have noticed the previous owners sometimes seem to stretch things a little when trying to make a sale intentional or not.
To get 50 out of your boat seems pushing it to me. Maybe 3:00 in the morning running on a silky smooth lake with 2 naked 100lb adults and an 1/8 tank of fuel + a gallon of cool-aid and a bb&j samich:D...........it works for me:eek:
Denny
gshldon
i have the same motor and i can run wot and get any where from 37 to 42 mph and i am using a 19 pitch prop, like it was said earlier it all depends on a lot of things, the main one i found is the trim of the motor so try playing with that and you will see the change in mph. Are you getting in the manufactures recomendation for rpms at wot?
Good Luck and happy boating
