Hey all,<br /><br />I was just curious if there is some a standard, or certain height an ourboard should be when trailering?<br /><br />My new Lowe FS175 when I picked it up from the dealer had the transom saver adjusted so that the bottom of the lower unit was only about 1" above the bottom of the trailer.<br /><br />The trailer is pretty low to the ground, and that scared me, so I adjusted it out so the outboard sits at more of an angle, and the bottom of the lower unit is further off the ground.<br /><br />I didn't know if there was some reason the dealer had it soo low, if there was some problem caused by having the engine raised up higher, or what, so I thought i'd ask..<br /><br />Thanks,<br /><br />-TheChad
