Britcheflee
- Oct 4, 2010
- 79
Well, when you work alone you have to be a bit inventive - so searched through the garage and came up with this (From old bolens tractor) set up as in picture . put bent part against my side and used big socket with good leverage...came right loose....now, need to find a puller to get that flywheel off....looked inside...coil cracked just as described when they go!!!!
I think I can use the same proceedure to put nut back on - btw do you grease the fittings inside when re-assembling flywheel?
I have also posted a picture of the viking I am working on - although there are three holes on the top there I am not sure if they are threaded (need to double check) - if not, not sure how to get flywheel off - anyone have any ideas?
Thank you,
Lee
Thank you,
Lee
