- Jul 23, 2011
- 50,786
I use a photo tach on the flywheel to verify the dash tach. I verify at a few different RPM's in a barrel on outboards. I use the same photo tach on the damper to verify tachs in I/O's
It appears to me it's at least 2" low. Assuming the holes are each the standard .75" apart, I'd start by raising it 2 holes. And loose the whale tail for sure. Once at the proper height, you won't need it. Just throw it in the trash. That's all they are good for.
That not right right Sea Rider. This is from a 2016 Yamaha manual so its not Jurassic.....
bow/stern weight can't be changed on most boats. At least not enough to matter when there's only one or 2 people and designated places for everything by design. Get the engine mounted right and it won't be problem. This guys engine is just mounted too low. It's that simple.Is porpoising the continued up-down movement the hull experiences when al plane ? If, so you need to shift more weight towards bow along an excellent transom/motor height match.
Maybe you need to go to work for a engine manufacturer as you seem to know more than the engineers that design and test these....Owner manuals,service manuals,Google and YouTube must be all wrong. WOW !! Guess I set all my satisfied customers and my play boats up wrong all these years....all Owner's Manual states the same BS and I have read them all.
