mastercraft98
- May 5, 2011
- 24
Hello. I was wondering how do you figure out how much resin you need to use for your csm or 1708 and other fiberglass cloth.I see that it comes in different .oz like 1.5oz or 6oz and the like. I either mix the poly :facepalm: to cold and it takes for ever to cure, or its to hot and by the time i get it to my projects it's already getting hard. I like like using epoxy just because if I didn't mix enough up I can go and mix up some more and continue on. with poly i either mix to much or not enough, and like I said if I don't mix enough up the first time it's to late for me cause the stuff I put down is starting to gel.
