How much water should be coming out when plug is removed
CaptTorS
I have a Jason 1570 fiberglass bass boat, as soon as I pull it out at the ramp, I pull the plug and a lot of water comes out, this seems a lot of water , is this normal on these type of boats?
ondarvr
Re: How much water should be coming out when plug is removed
"How much water should be coming out when plug is removed?"
None
Unless it's raining or people are swimming and getting water in the boat, the bilge should be dry.
CaptTorS
Is there a way if I bumped the swith for live well or bilge that it took on water?
Rd05lly
If there is a hose bad to live well.
pckeen
Hi Capt,
Welcome to iboats.
How much is 'a lot'? Are we talking about the plug hole draining for a few seconds, a few minutes, or what?
A properly sealed boat shouldn't leak at all, so there shouldn't be anything coming out of the bilge, but you should be aware of a few things. First, if a boat is out of water and gets water in it during rain, even if the boat is draining to some degree, water may collect in the boat beneath the floorboards - particularly if the boat is actually tilted slightly towards the bow. Second, even if the boat is tilted back, water may collect at some points beneath the floorboards - particularly if the drainage paths have become clogged with old dirt. When you then take the boat out and use it, the movement of the boat and action of accelerating can free up the water and send it towards the back of the boat.
If you have people getting in and out of the boat, a livewell that is running and sloshing water out of the livewell during motion, or water being splashed over the sides during movement - all this water ends up in the bilge, so that could explain some.
To work out whether your boat is leaking, I suggest the following. On a calm day, make sure the boat is fully drained before you put it in the water. Then take it for a a short run with a few accellerations and decellerations to dislodge any standing water in the boat. Use the boat in a manner that doens't let any water splash in over the sides. Then take it out and drain it on the launch ramp. Then launch it again and repeat the process. If you have water draining out the second time, you can be confident that the boat is leaking.
In terms of finding the leak - I know of ways of leaktesting a boat, but don't know enough to reccomend any of these ways to you. I would suggest a careful visual examination of the boat. If you cannot find any visible cracks or damage, the livewell or other 'holes' below the waterline, such as fish finder transducers could be the culprit. If you are just looking for a patch repair, you might try sealing those up (cheap and dirty is silicone caulking), to see if that makes a difference. Other possibilities might be a leak in the livewell infill our outflow lines. Of course - if you are leaving the livewell running - it may be filling up and overflowing.
Good luck.
four winns 214
Check to see what drains into the bilge. I realize that it's a different type of than yours, but on my Four Winns deckboat two small onboard drink coolers and the anchor locker drain into the bilge. A couple bags of ice produce a surprising amount of water.
Home Cookin'
"Then take it out and drain it on the launch ramp"
or open the hatch and look at the bilge.
remember, too, that a bilge pump doesn't get it all
CaptTorS
Thank you for your suggestions, I haven't taken it out again, yet, but, the water MAY have come from being outside in the rain, although I have a cover on it, I'm unsure how totally waterproof it is
CaptTorS
Would a plug be the culprit? Could it let water in slowly?
kjsAZ
there should be no water in the bilge if everything is as it should be. My drain plug sleeve got lose (age) and I always had about a pint of water in the bilge after a day on the water. Reseated it with 3M 5200 and now there's no water any more. However, when the kids go in and out the boat a lot of water will come in. Last weekend they managed to get at least 1-2g of water into the boat.
Covers sometimes also leak a bit or wind drives the water under the cover which is the reason that you should move the bow up with the trailer jack when you park it and remove the drain plug. That's why everyone once forgot to put the plug in before launching.... My drain plug was drilled through the square head and attached to the keys after I did it once.....
