how to adjust engine mount
finer things
about to install engine due to cracked block just need to know how do engine mounts adjust it is off a 5.7 260 h.p 1987 the mount has a bolt on the top and bolt on bottom with a steel thingy that is bent over to stop bottom bolt from turning I will probably need to align motor after install advice would be appreciated
Bt Doctur
Re: how to adjust engine mount
Make sure the adjusting nuts are loose before you install the motor. set motor in place, check alignment. tighten top nut . adjustment is done by raising or lowering the bottom nut.
finer things
so should i bend steel thingy on bottom bolt so it can move freely
Alpheus
If you took the bolts out that hold the engine mounts to the deck of your boat and haven't touched the 2 large adjusting nuts it should be close. You should disassemble the motor mounts to make sure that the threads are clean and that the adjusting nuts are not rusted and can move nice and easy. This makes this job a heck of allot easier. Take measurements of where the nuts are now by measuring the distance between bottom nut and the base of the mount. Remove the top nut, lock washer, mount, metal tab and make sure that the bottom nut can spin nice a free. Use penetrating oil to assist if necessary. Replace the bottom nut to the previous measurements and make a mark on the nut face using marker or a scribe. Use a pair of pliers to bend the metal tab flat or I use a rubber mallet and hammer it flat on a piece of wood. Assemble the rest in reverse order, but do not tighten the top nut. Leave about 1/2 gap at the top to allow for adjustment. After you have the motor dropped in, use your alignment bar and make adjustments accordingly. Make sure that you make the same adjustments to both sides of your engine by using the marks on the nut face to count the number of turn required. After you have the alignment set, tighten the top nut and check your alignment again. Sometimes tightening the top nut will throw the alignment off just a little, but it must be corrected. When the top nut is torqued down and your alignment is perfect. Bend the metal tab back down on the nut.
Sometimes it can be a hassle, but taking the time to do this job right the first time out will ensure that you are having fun out on the water and not replacing your Gimbal bearing, coupler and U-joints in the near future. Good luck...
Ayuh,... That's the Lock Tab,... Bend it back over when yer Done...
finer things
thank you the information is very thorough I will be working on soon
