- Jul 23, 2011
- 51,362
A$10 inline CB is dirt cheap compared to a TM
I doubt the TM was harmed by the PWM, no difference with the PWM at 100% or connecting the motor directly to the battery. Though it looks like the problem could be due to insufficient wiring. the TM can draw a lot of power as you saw, and thin wire and/or loose connections could cause all sorts of weird issues. Even for short wire runs and testing like you are doing, I would use at least 12ga wire, with all connections crimped and ring terminals bolted onto the battery(s). When you get this installed into the boat you will most likely need to use much larger wiring, 6 or 8 gauge. To calculate what wire you'll need to use, google "blue seas dc wire calculator" and run through their calculator tool. GenuineDealz.com is a good place to buy wire when you go to install the TM into the boat.
The motor won't turn with the end cap(s) removed, so you'll need to put it back together, then check if the motor will turn under power. You should also replace the end cap seals as they are supposed to be replaced anytime the motor is taken apart,,, water getting inside the motor is a kiss of death for a TM. Probably a good idea to oil the motor bushings while it's apart. I used to have that exact same TM for 10 years, worked great without a hitch. Check all of the pedal switch positions as the toggle switch could cause the no-run problem like you're seeing.
For the breaker, just add a 50 amp between the TM's + wire and the batteries + terminal.
I'm interested in your setup and testing since I hope to put a TM on my boat when the time comes. Here is a thought, many motors do not like pulsed current such as comes with square waves. I wonder if adding a large capacitor between the PWM and the TM might make it run quieter. At least that should round off the edges of the PWM output. Just thinking here without any experience doing this on a TM. I know that a .01 mfd or less capacitor can short out some high frequencies noise on a household circuit whereas a large capacitor will just pass them through. Just use a 400VAC or higher rating.
Since you like testing I'm just curious.
Good luck with your venture.
