Re: How to change lower unit oil?
ihfreak 402,<br /><br />if you look around the front of the gearcase you should see a screw abouut the diameter of a dime there is also one one foot above it these screws mark the top and bottom of your gearcase remove the bottom and top screws with a pail under it to drain the gear oil after it has drained, YOU MUST FILL THE LOWER UNIT BY THE BOTTOM SCREW HOLE!!!
