Re: How to dry soaked carpet properly...?
Pressure washers DO destroy the smooth surfaces of plastics easily. So start at a safe distance in a NOT visable area to see how close & how long you can spray a area.
Spider **** is a stain that I can only remove completly on a white surface. At least the 1 type of spider poop I have locally. It is a orangy color. I use a white paper towel & full strength bleach In bright sunlight. I wear rubber gloves. As I rub it every 30 seconds till the stain disappears. full rinsing.
On colors I use Fantastic the same way. Rinse the Fantastic off several times.
