Lou C
- Nov 10, 2002
- 13,389
Re: How to instal a new sterndrive?
Sounds like you are well on the right track. I would not change what you have for a Merc set up because of the cost of the transom and engine mount work. That is work that requires specialized skills (wood/fiberglass) and being able to tolerate working with stuff that is pretty unhealthy (fiberglass dust=very bad for your lungs, fiberglass resin=bad vapors) I'd rather buy a new or remanufactured engine if its needed than rebuild a transom and if you had to pay for the 'glass work it is pretty expensive.
You are not mentioning problems with the drive itself so you are really just having to sort out the issues with the Volvo 2.3 4 cylinder. They are good engines when maintained well and in good tune.
