How to make a 6hp have more power/thrust????
14 foot Starcraft
Re: How to make a 6hp have more power/thrust????
Ive even towed a tube using my 6HP!
With the 3 of us, we had a good 600 pounds in that boat, and the drag from the tube.
Did just fine.
Mine does not look like that behind me lol! I couldn't pull a tube very fast at all if i wanted to
14 foot Starcraft
I wouldn't bother trying to boost anything on that 6hp. It'll cut into your beer time and it's not worth the money. The 6 is a great motor, but it's best to just buy something bigger.
Yah I love my little 6hp but my friends always gripe on how its so slow lol. I have been looking for a 9.9 or 15hp but I don't have the cash for a bigger motor yet. This motor will last me for ever if I just get used to it and keep my eyes open for a 9.9
Photoshop on that picture ???
14 foot Starcraft
This is whats in my cart right now what do you guys think??!! I need the part number for the grommet that connects the water outlet of the pump to the inlet pipe. My gear case lets water in so last year I just changed it about every three uses. The fill drain plugs have been cross threaded in the past and they go kinda crooked but I have a 64? seaking 6hp lower unit case with non stripped fill drain plugs that I'm hoping will fit. The impeller was new a year or two ago and I turn the motor over a half turn every month of the off season so keep it from stiffing up in a bent position. THANK YOU FOR THE INPUT!!!
Solas Amita Aluminum Boat Propeller #2011-083-08P for Evinrude 6 HP Outboard 1966 - 1979
Lower Unit Gear Housing Seal Kit for Johnson, Evinrude, GLM 87616 - Sierra 18-2680
Thermostat Kit for Mercury, Mariner 75692 - Sierra 18-3672
nwcove
id save the money for the prop! doubt it will be worth the money. are you sure on the t-stat number? oh wait, i see that the part number is for a kit, was looking at just the number for a tstat. a pic of the transom with the motor mounted would be nice.
14 foot Starcraft
sorry the boat is upside down with snow all around and the motor is in the basement. I will upload some pics though
MikDee
Banned
I'm going out on a limb here, how handy, or daring are you? I never tried this, but I'm an old wild, & crazy guy,,,lol. Maybe if you get the new prop, you can re-route your exhaust down the leg, and out the prop? If that's even possible? leaving a little weep hole where your exhaust is now, so can check if it's pumping water. I'm sure the exhaust will provide some extra thrust, especially at high speed.
Not sure how you would get the exhaust to go out the prop ??-----Good project for engineering students I would say.
14 foot Starcraft
I will just use it and look for a 9.9 i don't want to damage my motor. I am very handy with a motor but body work like that is not very good
BigB9000
Real pic! Engines do great when they run right.
Part number is:
0302497 GROMMET,Water tube ($2.99)
And yeah, you wont be converting to thru-hub exhaust.
nwcove
id do some measuring to see where the anti vent plate is in relation to the bottom of the boat. yer still not gunna get on plane, but if the motor is hanging to low, you may gain a little bit by raising it.
14 foot Starcraft
Part number is:
Real pic? It would be on the water today but the lakes are froze over and its 20 degrees
