How to Protect Gunnel When Deploying Anchor
GA_Boater
Re: How to Protect Gunnel When Deploying Anchor
The one with no chain. The one with the chain belongs on a naval vessel like the Forrestal, not a small aluminum skiff.
Downsizing the anchor and chain will make a world of difference.
JimS123
The one with the chain is called a navy anchor. I have an 8 pounder on my 14' tinny with NO chain and it works perfect even in a current.
JASinIL2006
Minuteman , don't feel bad... I have a Navy anchor and about 10' of chain, and that thing is a bear to haul into the boat! I picked up a Danforth at the end of last summer; I'm hoping it's a bit easier to handle.
minuteman62-64
OK, the Danforth it is. I'm going to keep the Navy anchor rigged in case a use comes up. So, I'll rig up the Danforth with new line, chain (shorter than 5 ft.) and fittings. The existing line is circa 1982 and probably due for replacement anyways.
Thanks, guys.
LippCJ7
In all honesty minuteman, I think I would give the Danforth a shot without the chain, see how it does, if you feel you need the chain its not like its the most difficult job in history to shorten the chain and reattach it.
I'm pretty sure the 25 lb. Danforth with the chain (your current setup) would hold the USS Nimitz....
Love the Danforth Anchor.........:laugh:
minuteman62-64
..... and anchor chain. After reading about 50 posts on this issue, it appears I'll be "wrong" with about half of the posters no matter what I do. Looks like there are benefits (chafing protection, etc.) that go beyond making the anchor dig in. I'll go with 2-3 ft. of chain.
LippCJ7
I don't think you are wrong buddy, I would say that you are very prepared, you know for something like Hurricane Katrina LOL, the tried and true way to set up an anchor is to have the right sized anchor for your boat with the right amount of chain, now you may need a larger anchor and more chain due to the conditions you boat in and the results you are looking for.
So lets say you like to fish in the mighty Mississippi, you have a boat like mine 25' bowrider that is 5000 Lb's with a lot of freeboard on a windy day, we know that the Miss is a pretty muddy bottomed river that has a good rate of flow and I do not want my boat to pull the anchor.
In this situation I need a setup like yours which ironically I have, it will hold my boat in those conditions, no kidding. But we are talking about your boat which is much smaller with much less weight and freeboard so just by those factors alone we know you are way over sized, now if you are concerned about banging your boat the simple answer is to downsize your anchor setup since you can! If you feel you need to keep your existing setup that's fine get another, much smaller anchor and less chain and save your backside and damage your boat less.
I can tell you the way I set my anchor but Its not going to help you much since you have a different boat but what I do is I hold my anchor in one hand and I loop the chain and hold it in the hand closest to the bow, I then twist my body and throw the anchor as far as I can and release the chain clear of my boat. Retrieval is pretty simple but much tougher if I pull up a bunch of mud which is pretty common where I boat, I have an anchor locker and I use my throwable life preserver to protect the gelcoat from chain damage, my anchor gets cleaned of any mud prior to going into the locker which also helps with ANS inspections when leaving the lake.
I love my boat so its just the best practice to take your time and don't hurt yourself! Don't take anything as doing it wrong though, we all have our different ways of doing things!
ondarvr
People frequently make suggestions with what they know from local experiences or locations, not necessarily what may be right or wrong in other places or conditions.
Where I do most of my boating a 25# anchor on a 17' boat would be considered small, 35 to 45# would be more common, mine has a 55# anchor. There is no chain and they are deployed differently, there is a bow roller and normally a can the anchor slides into.
Here is one type.
LeeLock Anchor Systems For Power Boats
minuteman62-64
Went to Walmart today. Got 150 ft. of Attwood 3/8" anchor line, with galvanized thimble, for $38. Four ft. of 1/4" Attwood anchor chain for $16. Old chain was 5 ft. and 5/16".
So, hooked up to 5 lb. Danforth anchor results in considerably lighter (but hopefully still effective) package. See photo - problem solved.
LippCJ7
Good deal! Let us know how it does!
greenbush future
Will do. Although it may take awhile. Since I put the boat back into service, four years ago, I've anchored once :)
The one in your picture should be fine. The amount of rope you let out will have a lot to do with how well it holds. More is better in most cases, but then you could be swinging quite a bit in the breeze. That's where a second mushroom anchor off the back going almost straight down come's in handy. I do this for perch fishing to get my big boat exactly where I want it. over the weed bed, and it works!!
minuteman62-64
New line is 150 ft. Measured old line today - was only 84 ft. Should be better in that aspect also.
Home Cookin'
test your anchor now in a non-emergency situation; try it against strong wind/current and different bottoms. better than learning during a crisis--your anchor is your most important safety device. if your rig doesn't work well for your conditions you can fix it.
I have had danforths slide along sand bottoms and not grab in fast current. Chain is part of the solution to that, as is longer scope (more line) because it works when it lays flat.
Also in current, especially now that you have a lighter anchor, the anchor will get pushed with the current while it's being lowered, so you end up hooking downstream and behind the boat. While you don't want to throw an anchor, in current you should drop it all at once, not lower it--unless it doesn't matter where you end up.
