Re: How to Remove Brake Hub (EZ Load)
I assume these are drum brakes? Although I'm not familar with removing trailer drums, on cars with drum brakes you often have to use a screwdriver or brake adjustment tool to adjust the brake shoes in before removing drum. As the drum wears, a ring is created around the edge and the shoes expand into the worn area and won't come over this ring. On back side of wheel housing is a hole you adjust them through. Inside hole is a little "star wheel" you turn to adjust breaks. As I said, trailer drums maybe totally different though.
