How to remove powerhead 83 evinrude 140
aviator79
Re: How to remove powerhead 83 evinrude 140
Ya, but if my waterpipe leaks inside the midsection it is not supplying enough water to the engine and it will overheat. I had water coming out prop exhaust and all around lower end to mid section. Assumed it was due to seal between the mid section water tube and water pump but when I separated and saw all the water that was leaking out of the mid section thru the water tube, as I was feeding directly into the water tube, made me realize I had a leak in the tube or at the top where it seats and the mid section needed to come off. Had I know it would be this much work I would never had attempted it. Possibly would have been fine. Maybe once engine was in water...I dont know but did not want to sell it knowing something was wrong. Too late now. Going to go drill out the last bolt.
aviator79
Is there a trick to remove lower engine cover / cowling with ppowerhead on? Seems others have done it. But i cannot figure it out. Removed carbs and trying to push it forward to clear lip, but no luck. Not sure how to cut bolt as it is in the way...
aviator79
Split the bolt and was finally able to pull it with lots of prying. A mess...
aviator79
well there were no holes in the water tube so guess that was all for nothing. So either it is suposed to leak or it is the sealing surface that was not sealing or?
