So I used Don S. handy guide on diagnosing starter problems and determined my starter solenoid is bad. The A terminal has 12.5 volts power and the B terminal has .05 volts. The rest of the circuit: slave, breaker and ignition have the same .05 volts. Am I correct the starter solenoid is bad?
How can I remove the thing? Its tucked under the riser?? and there is minimal room to get my hands in there. I see what appear to be 3 screws in the back of the solenoid but they are odd shaped and I don't have room to get any common tools back there. Do I need to remove the riser?
Here is a picture of the screws. Any tips on how to remove the starter solenoid would be much appreciated! Thanks in advance.
