how to tell what outdrive you have
bob johnson
new to the I/O fraternity. Picked up a 22 ft islander with a 165 mercruiser in it. the outdrive was rebuilt and installed 20 years ago and then never ran....but i can see that there are no trim cylinders on the unit....
so i know ill have to aquire them at some point, and i want to start looking now. Plus i bought out a marinas supply of parts and I have hundreds of gaskets sets for outdrives of all makes and many are for mercruisers of different styles....
so before i offload these gaskets, impellor kits and outdrive parts, i want to set aside all the parts and gaskets that fit my motor and outdrive.
soooo where am i looking to tell if i have a bravo or alpha and what #?
heres my outdrive before i dragged the boat homeZ:
thanks
ziggy
Re: how to tell what outdrive you have
to id your drive. have a look here. it's from the adults only sticky. the very first thread in the i/o section. the second item from the sticky. mercruiser information.
bob johnson
yeah those links are blocked by my companys server
its like they are entertainment based or something....because nothing else from this site gets blocked!
ill have to wait till i get home and check them out
bob
Ayuh,.... It appears to be an MC-1, but clickin' Ziggy's link will help ya verify that...
It's Not an Alpha 1, nor a Bravo...
bob johnson
Try this one, has different links. http://forums.iboats.com/mercruiser...ow-identify-alpha-style-outdrives-592828.html
Also, your problem with the link ziggy gave you could be the title of the thread (Adults Only) click on the link just below it, same info, just a title change.
thanks, i have the MC-1 outdrive... and luckily , I have a bunch of gaskets and seals that fit that unit...which I has the two trim cylinders though.
bob
