how to test trigger
Nickmell
Re: how to test trigger
Try running a short jumper wire from the red terminal on the engine block to the blue terminal. This will supply constant power to the distributor electric eye and the CD box electronics. (remember: Red to the CD box already supplies constant power to the capacitors only). If you now can get spark while cranking, replace the switch and/or the cable. If the switch is bad then you are good to go. If the switch is good, then the cable has an intermittent break in it (not likely) Simply run another wire from the ignition switch to the blue terminal on the engine.
Sounds easy enough ill give that a try friday. I hope it works im very close to finding a mechanic to work on it.
Nickmell
Well ran the jumper and loose all spark, when I take the jumper off I still get thespark from the key so im going to check for a short somewhere.
