How upset would you be?
cchamp
I took my boat to a mechanic who did a number of things for me. One of them was remove a broken starter bolt (earlier post on this board about it). He ended up having to pull the engine, and did it during his high season. I was very appreciative that he would do it. A number of shops I talked to wouldn't even take it on given how labor intensive it was.
I also had him do the gimbal bearing and requested he do my bellows. I had a leak coming in through my shift bellows, upon inspection it had a small tear in it. Now- the rest of the bellows are currently water tight but they are going to bust leaks at any time. They've lost all elasticity and are hard to the touch. When we talked about what I wanted done to the boat we discussed that he might as well do ALL of the bellows since he was in there. The guy ordered an entire bellows repair kit, and charged me for it.
Get home and start poking around back there and damn sure he only replaced the shift cable bellows. So now I'm going to have to go back in there and replace everything myself. If he didn't do that did he do the seals etc?
What would you all do? I'm both happy he got the starter bolt out and pissed that he would do something so damn stupid.
TunaFish389
Take it back in till done right... I would rather pull engine then change some bellows. Looks like great minds think alike.
cchamp
Ha! Well- the place is 45 mins away and one thing I don't want is a mechanic that doesn't like me working on my boat. At the very least he needs to provide me with the parts he charged me for that he didn't put on the boat.
I would have done it myself but the bolt was simply above my abilities. Maybe I'm just going to have to do it and put some TLC into when I do. Just frustrating.
Either take it back, or do it your self
wellcraft-classic210
Master Chief Petty Officer
If you do not find the mechanic trustworthy when discussing the issues -- I would not expect him to fair either -- and his competency would also seem to be in question.
In either case :
-- I would suggest you do it yourself or go elsewhere to avoid added troubles.
[h=2]How upset would you be?[/h]
Ayuh,...... Donno,........ Never done that,........
