Hull cleaning
DeepCMark58A
Starbright hull cleaner opinions? I washed the hull, it is stained I tried soft scrub, not good enough. I ordered the hull cleaner the reviews are good, figured I could get real world results here. Also ordered starbright mold and mildew satin removal spray. I finally got the temp sensor and fuel filters changed now it is just clean up.
DeepCMark58A
Never mind I got a tip over on a master craft site. Toilet bowl cleaner I applied used a scrub pad to distribute it evenly let it sit for 5 minutes. Holy crap it got rid of the stains by the trailer fenders where a buffer can't reach. just rinsed it off. Can't say how impressed I am I spent 6 hours buffing last year trying to get the stain out, now I can spend my time waxing.
DeepCMark58A
Nope used the lysol cling rubbed it in with a scubbie and set the timer for 5 minutes saved me hours of buffing that I can dedicate to an extra coat of wax
DeepCMark58A
This was the side of the boat after I washed with boat soap then used soft-soap and started buffing
eggs712
Good to know, thanks for sharing. Any particular toilet boil cleaner or active ingredient to look for when purchasing?
airshot
Neighbors use "Lysol rust and stain remover" for toilet bowls. Squirt it on, use a soft scrubber like used to get bugs off your windshield, to smear it around. The crud just melts off within minutes. I have used it on my painted aluminum hull on some really tough stains and it worked great. Once cleaned up, get some spray on auto wax and spray the whole bottom. Makes future cleanup so much easier. No need to buff on the bottom, sides only need light buffing.
crazy charlie
I have used them all (bowl cleaners) best is Lysol 10X ,3 pack for $5 at Wallyworld. Dollar store ones wont work ,though they used to but just about everything there is watered down including the bleach. This stuff will stain your trailer so tarp it off or be really careful. Charlie
Marykate on and off is two kinds of acid and acetone. It cleans most stains, but wear gloves and protect the galv trailer parts.
