hull extension in progress with pics
Status
Not open for further replies.
oops!
Re: hull extension in progress with picks
bw......keep posting those upholstery pics coming mrdjflores
im looking and learning. ;)
HopeSheFloats
Yes if need be, re design the beer cooler, or else decide who will have to 'tag along next time' ;)
I haven't commented much in here, but believe me I've been awatchin....you da man!!!
msalvatore47
oops!, your an inspiration. haha i love this thread. when ever i feel like i cant get my rebuild done and i feel like givin up i take a look at what you've done.
good job. you need to make this thread a book.
oops!
thanks guys......
i appreciate the kind words....
im goin back to the shop now......got more to do...!
ill get some pics up for you guys tonight.
cheers
oops
SnowHunter
Glad to see ya finally got it on the water, oops!!!!!! Outstanding!!!!! Sure have come a long way from the first post!!!! Can't wait to see more pics :D Keep at it!!!!!
mrdjflores
pics...pics...pics.....!!!!!!
pics, our drug of choice....lol
one a different note, do you have much experience painting aluminum trim?? i want to paint my window frames black...any suggestions??
proshadetree
Im in I want pics and updates. Great job are you going to strech that pull truck?
redfury
I'm waiting for a grinder dust collector to get her from Amazon.com next Monday ( sooner if I'm lucky ) so I can finish grinding out my boat and get that center stringer done... I made some 1/4 ply deck templates so I have something a little more "solid" to work with than the foam I used to create the first set of temporaries....I'm stoked to get some real work done on my boat this year. I might even get it wet ( sans interior or motor ) just to make sure I'm in good shape.
Good luck with the Upholstery Ward, you get less "do overs" with sewing vinyl. ;)
mrdjflores
hey now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2 days without any updates!!!!!!!!!!!!!!!!!!!!!!!!!!!
i see your gonna make me hop in my truck and head up there to get things moving again!!!!!!!!!!!!!!!!!!!!
oops!
hey bud
lol.....i got some in my camera now....
i was just doing some net shopping for a sewing machine.....
there is a straight stitich juki industrial i was looking at....but it doesnt have a walking foot.
any how....im gonna whip out and grab a dairy queen sunday....then ill come back and load some pics.....
oops!
lol....
as long as i bring one back for her.....hee heee
actually im at home so i can use my puter.....im not allowed to go on i boats at her house.....:eek:
mrdjflores
the sewing machine i've been using doesn't have a walking foot. Keep in mind, when your sewing the vinyl...the backside of the the bottom piece of vinyl (when sewing it) will be against the stepper plate, that will move the vinyl along nicely
INJUN
Use leather. Apply loosely.:)
oops!
im planning on doing some fairly intricate sections.
as much as 8 layers. do you find that the top layers move or "spread" when using the standard setup?
like as far as the piping between sections?
Boater45
ok......where do i start.......
first of all ...........all the things i had to do yesterday turned out to be juuuust a little amitious for the 12 hour day.......
when i had left the boat it was finished to a 400 grit......that means i needed to go 600....800....1000....and finally up to 1500.....
i needed to find a way to do it fast but through
after hours and hours of sanding....this was the boat with a 800 grit finish
the side were starting to come out
Very nice work......I like the two handed sanding.
oops!
im really having a problem with photobuckets bulk uploader.....it doesnt work so i have to upload everything pic by pic.....
i was uploading these last night.....
this is going back to the coupler fiasco that don s and robj bailed me out of.
the standard coupler these days is a triangular style that bolts to the outer edges of the flywheel.
the older style used for pre 80's applications was a kinda mushroom/bell shaped peice.
the older style is a little longer allowing the drive shaft to be inserted farther into the coupler....this is only by a half inch or so...
if you notice in the above picture.....the bell shape of the coupler does not allow standard crank shaft bolts to be used.
they actually used grade 8 studs for this job...
do you think the studs are easy to find?
on top of that ....there are 2 length of stud sizes...we needed the longer ones.
it took us all day on the phone and driving around to get 6 studs.
the shorter thread end of the stud goes into the crank shaft.....
the longer end is for the flywheel and the coupler and the washer and the nut.
well....the problem with the studs.....is that they nust be installed into the crank at 55 lbs of torque. so ....that means you have to double nut them....torque them to 55 then slide the fly wheel on....hammer that into place....install the coupler...then fit the washer and nut in a tiny area and torque that to 55....
after i got all the correct pieces ... it took me about 10 minits per stud to install....then another 10 per stud to finish with the coupler due to limited access with the open end wrench....so to install the coupler and flywheel....it took over 3 hours (including beer and cuss breaks) to install these parts.....
man am i glad they work :)
ok....ill have more updates on the latest when i get back from the shop
cheers
oops
mrdjflores
a few of mine are 8 layers thick...but you don't sew them all at once...you build up one layer at a time...
i'm almost done with my video....i think i captured every aspect...i still have to shoot the part with stretching the vinyl over the foam and ply base...
i'm planning on stitching all the videos into one and put it up on youtube or photobucket, and then link it on here...
one suggestion....buy plenty of needles
mrdjflores
here is the seat base that is on top of the engine cover...
here is how they will be laid out in the back of the boat...
Status
