Hull ID Need Help.
Jim Taylor
No serial number plate, Rated @ 35 HP. MAX.(Plate) Mfg Tag shows Both Grand Prarie Tx. & bremmen Ind. Measures from Bow to Stern 14.5 Foot. Was told by Locale Boat shop that this model was the template for the Orlando Clipper Model, They said that the rivett pataren On the sides back by the stern is how they determined that ,But I do not recall what year it was or what it is called.The Bremmen Ind. Plant did not open till 1954 Here are some pic`s. Hope someone might Know what I have here. Thank`s J. Taylor
southkogs
Re: Hull ID Need Help.
Is that a Lone Star? Definately late 50's early 60's - and I think Lone Star was manufactured in both Grand Prarie & Bremmen. Take a look: http://www.fiberglassics.com/library/Lone_Star
Finding the actual Hull ID is going to be next to impossible most likely. They didn't start stamping those until the 70's typically.
Welcome aboard Jim.
Jim Taylor
Thank`s for the reply,Still checking out Library @ fiberglassics. where do you measure the "Beam" on the hull? My guess would be the widest point?
menglor
since the boat is register in florida, could you not get the hull ID by contacting the coast guard or soemthing?
southkogs
Yes, Beam is the widest point on the boat ...
... Beam is also a common beverage for helping you when you're getting frustrated finding out which boat you have :D
