Hull Number
Lee G.
I just acquired a 1929 26' triple cockpit runabout...where do I find the hull number on this old boat?? Does it even have one??
first, welcome aboard.
HIN's came out in 1972 and were revised a bit later to the current standard. so there is no hull number
for 1929, it would be a hand-built boat and may not have a builders tag with a serial number
if you dont have paperwork, get it.
Lee G.
I have a title and it indicates a hull number, but I wanted to verify it on the boat...not sure if I will ever find this number anywhere on the boat, so not sure how there is a hull number on the title.
look for a brass builders plate. would be on the inside of the transom or the side of the gunwale.
will be a serial number with only a few digits.
12 character HIN's came out after 1972
could be a state-issued HIN
jbcurt00
State issued/assigned HIN when boat sold/transfer. Typically includes metal plate w HIN to be permanently attached to boat, top right area of transom when viewed from back of boat
What are 1st 3 letters @HIN @title?
Run What the title shows thru www.hindecoder.com
however it should have patina on it like the following:
